Is there a firmware update for this camera? Can't find a link to any version ever for this camera. A lot of things are broken with the camera such as the IE plugin isn't signed properly, mac support, the API doesn't work.
Also, what is the snapshot URL to get a snapshot from this camera? I am just using it w/a NVR, so I am looking to do everything direct on camera.
Firmware for ip3m952e
Re: Firmware for ip3m952e
I didn't find any update for ip3m series...
@melvin - can you provide status - i was told a firmware update was coming out for this camera.
Hello ghctim,
The camera does not have any update available yet. We will follow up with the developers on this and update you.
Bump. Where is the promised update?
Hi,
the firmware upgrad has arrived:
build 16080801 11.5MB Only for IP3M952E
How can i install it? Uploading it via QCAM SmartClient (Maintenance) gets me an error:
Upgrading fail! Device is rebooting!
What to do now? Please help me, amcrest/QCAM!
Hello skoenig ,
Is the camera connected to the back of an NVR or is it directly connected to router through a switch? If directly connected to NVR, it might not work properly.
Hi,
the camera is directly connected to the router.
