Firmware for ip3m952e
Melvin
Re: Firmware for ip3m952e
Post by Melvin »
Hello skoenig,
Could you please reset the camera by holding the reset button on the wire coming out of the back of the camera for 30 seconds? Try to update firmware after this and see if it goes through.
skoenig
Post by skoenig »
Hi Melvin,
tried this but the error shows up again (at 15% progress).
what to to next?
skoenig
Post by skoenig »
Update: I have a second ip3m952e bullet cam. its a brand new, unused camera. same error, whats wrong with this firmware file?
and the checkbox "update configure file" has no effect, all attempts failed.
skoenig
Post by skoenig »
Hey Melvin, what's up?
Melvin
Post by Melvin »
Hello skoenig ,
Not sure why it does not work for you. We have tested it today on our IP3M952E and it worked just fine. We used smart client and the update option under maintenance. If the cam is connected to router with a very long Ethernet cable , try a shorter one for update.
skoenig
Post by skoenig »
Hi Melvin, LAN cable was indeed long. Tried it with a shorter one, no success. Kaspersky is disabled too. I'm very frustrated with this situation, so please give me further instructions/ solutions. One of my 2 cameras is brand new out of box.
B.r.
Stefan
Melvin
Post by Melvin »
Hello skoenig ,
Did you try this from a windows computer or MAC? Try on Windows computer if that has not been tried.
lbutlr
Post by lbutlr »
wait a minute? We are not supposed to connect our cameras to the 8 ports on the NVR?
QCAM HD with 8 IP3M952E cameras
t84a
Post by t84a »
I believe to update the camera firmware, you should connect the camera directly to your network.
lbutlr
Post by lbutlr »
How do you actually go about checking the firmware version on the cameras and updating the firmware? I looked for instructions, but haven't found them.
