Cameras Offline After NVR Reboot
Re: Cameras Offline After NVR Reboot
Sorry it is looking like that your NVR don't have a Security Page after all. That is very strange. I am going to guess there was some issues within that page and was written out at this time. I am going to guess that it will be added back in after a Update maybe? To me I find it odd that all my older DVR/NVR's have a Security Tab on both the WebUI and GUI of the recorder...
Have you made a Ticket with Acmrest over this issue? If you have has there been any update to what might be going on from their end?
ITGuy1024
Post by ITGuy1024 »
Not yet. It wasn't really a big deal. Sometimes community help is better / faster.
I'm going to do a reset on it and see if anything improves.
I had my old amcrest nvr replaced 2 times before I got a stable one.
Also looking at just running something like zoneminder.
YodaVader
Post by YodaVader »
I just rebooted my NVR and now none of my cameras will come back online :(
NVR4108E + 5 Amcrest IP5M-T1277E-AI Cameras
Amcrest NVR4108E
2 IP8M-2779E-AI Cameras
Edge in IE mode for WebUI
Pogo
Post by Pogo »
You're just havin' a helluva time.
YodaVader
Post by YodaVader »
Ok, finally figured this BS out.
Rebooting the NVR makes it forget the (AI) camera passwords.
#1 In the NVR WebUI, click "managment" and select "Camera".
#2 I see all the cameras with a red dot under "status".
#3 One by one I edit them and enter in the correct password that I set the first time I accessed them directly because I did not leave it as "admin".
#4 Refresh the page and they are all back online. (Green dot under status)
Amcrest NVR4108E
Pogo
Post by Pogo »
Easy when you know how, eh?
swbrains
Post by swbrains »
Thanks for this solution. I had to reconfigure my NVR and re-add each camera. Afterwards, they all had red dots. I had forgotten to update the passwords when I re-added them. This post reminded me to do that and now they work fine.
