WCAM895 replacement antenna for distance (?)
What would be an antenna that has a higher gain for some more 'reach'....and fits ??
note: Foscam 9dB antenna will NOT fit, as antenna has a center PIN,
whereas WLD895 antenna is reverse: it has center SLEEVE.....maybe is "RP-SMA" type connector(??)
I only need small gain.....I'm aware there are more (complicated) ways like range extenders / repeaters, but they're another hassle and failure point.
