Hello
I have a NVR2108 and backup of saved videos is really a pain.
To save 25GB it needs 5h, to save 87GB needs 14h on an external USB disk...
What usb speed has the NVR2108, usb1 or usb2?
I'm thinking to change to a NV4432E 32, but in the spec there says usb2, will this device save files more rapidly?
How to you save some of you stuff?
Title NV4432E 32 of Supports up to 24TB HDD, but has only to connect one HD? Can you tell me which hard disk today has 24GB which is not an array???
Greetings
Beat
usb speed of NVR4108 and NV4432E 32, backup very slow and how to put a disk with 24GB in NV4432E 32???
Re: usb speed of NVR4108 and NV4432E 32, backup very slow and how to put a disk with 24GB in NV4432E 32???
Hello tkmbe99 ,
The NVRs support USB 2.0.
The NV4432E has four HDD slots and you can connect 4 x 6TB HDDs.
