Two cameras lost connection p2p
drd
Post by drd »
I have 814B ip cameras and both were working using Surveillance Pro on the same network and off the network for the second camera at a different location. Both were set up using the SN on the android app and pc app. This can't be on our side at 2 location using different routers and connections.
What broke at Amcrest?
drd
Re: Two cameras lost connection p2p
Post by drd »
thats 2 841 not 814, sorry....also does work on cloud, but only have one connected
drd
Post by drd »
Too bad these cameras have this issue. Kind of makes them useless. No remote control etc. Can't change router setting at business location because the router is not ours. These are not ready for real use just testing...should be an Alpha product in delvelopment.
