I'm unable to complete adding a new device. I get to the point where you go to live view and it won't connect. I have two types of WiFi cameras and they both act the same. I've done factory reset multiple times. I've uninstalled and reinstalled the app several times with no luck. I'm using a Samsung Note 8 on Android version 8.0. It doesn't matter if I use WiFi setup or wired Ethernet setup.
Thank you for any help.
Trouble adding WiFi cameras to Amcrest View Pro on Android
kcperry1954
