Surveillance Pro not finding my system - States off-line
papster33
Post by papster33 »
I have had my Surveillance Pro set up for a while now, and everything has been fine. However I tried to sign in today and I can get on line, but when I try to view anything on my system is states that the cameras are off-line now and cannot be checked. I have rebooted my computer, the security system.... but no luck. I know it is working since I can see and use the system directly, and it is also working on my phone (Amcrest View Lite). That tells my all of my wireless and settings are working correctly.
Suggestions on why my Surveillance Pro would suddenly stop working? I had used it less than a week ago. No other problems with the internet on my PC.
lmm
Re: Surveillance Pro not finding my system - States off-line
Post by lmm »
have you tried uninstalling the app and starting over...
papster33
Post by papster33 »
No, but that is likely my next step....
