Stopped viewing no connection
maio
Post by maio »
Stopped viewing no connections
Re: Stopped viewing no connection
Hard to say what is going on. I have NVR's that are not full or DVR's that are not full and if I happen to forget and load the whole system when I get to a Channel that isn't online I get that message.
So it might be at the time that the message is going on your camera is doing a reboot, or maybe there is a Network issue and the Cell Service is to slow.
Or last thing that comes to mind is that you changed the system to have 5 or less then normal connections from the area within the Network tab, Then if your system is at Max connection you can get that notice as well. Like one of my cameras I set for 5 and had it setup on 2 recorders, ASP, AVP and after I tried to log out and back in I wasn't able so I changed back to 10 and no issue since.
However to better give you aid would need to know what hardware your working with.
