Stepper motor of IP4M1051B
Khushi
Post by Khushi »
Hello
I am working on controlling the motion of the IP Camera model 4M-1051B but to do so i need to know the driver used in the camera to connect to the stepper motor. Can someone help me with what driver could have been used?
Thanks in advance.
jack7
Re: Stepper motor of IP4M1051B
Post by jack7 »
You could try using the PTZ control command that is at
https://support.amcrest.com/hc/en-us/ar ... TP-API-SDK
you could also try using ONVIF commands.  See onvif.org
