Static ip set up. Pls help!
Hello,before i had a dynamic ip set up and now ISP upgraded my internet connection and i have got a static ip. But i need to set it up now,what should i do to make it work properly? At he moment ims till using it via p2p with dynamic ip (when i restart my router i get a different ip every time like 192.168.0.105 etc). But i want to use a constant ip all the time. Do i need to port forward some ports or maybe anything else? THANKS A LOT!
Re: Static ip set up. Pls help!
Hello gekanukr ,
You need to set up port forwarding for the http and TCP port and then you should be able to use your static Ip from outside. Please contact our support team if you need any assistance with the set up.
https://amcrest.com/contacts
