Whenever I have the camera system DVR plugged in to my router via Ethernet so I can access the system remotely it causes me to need to restart my router daily for the WiFi to work again. The Ethernet continues to work only WiFi goes down. Have tried different types of netgear routers to no avail.
If I unplug the camera system from the router the issues with having to restart the router daily goes away.
Any ideas what is causing this, perhaps I need to adjust a setting?
This has been really inconvenient.
Thanks for any help,
Dylan
Router Requires Reset Daily When System Plugged In
discovery3
Re: Router Requires Reset Daily When System Plugged In
I've had a somewhat similar problem with my IP2M-842 cameras and the issue is the camera......all 3 of them. I installed an eWiLink WIFI plug on each camera power supply. Twice a day, the plug automatically cycles power on each camera. That made the difference in usable vs an unusable camera system in my case.
