Previous firmware (16R) for IP2M-841W
couak
Post by couak »
Hi there,
Since the upgrade with the latest firmware (AWXX_Eng_N_V2.420.AC00.17.R.20170322) I issued invalid video recording : on video motion, the created mp4 stored on my FTP server is stragely small (always between 1Mb to 2mb) and record only 4 seconds (3 seconds stuck on the first frame, then stop)
Hence no image on the video, duration always <4s (in despite of the 10s record delay and 10s relay-out)
Where can I download the previous firmware ?
Thanks
David
Melvin
Re: Previous firmware (16R) for IP2M-841W
Post by Melvin »
Hello couak ,
Did you hard reset the camera after firmware update? Please try that if not done already.
couak
Post by couak »
already tried a reset, how to "hard reset" ?
Melvin
Post by Melvin »
Hello couak,
Press and hold the indicator light on the back of the camera for 10 - 15 seconds. The light will turn red and the camera will do its initial pan/tilt after this. You need to set up the camera once again after this as it will reset all the settings.
