Outdoor PTZ camera has Position issues?
So today while my camera was in its normal spot I panned it around a few times then put it back to Preset1 (Home Position) Then I wanted to look at a preset that I had setup and when I clicked on that preset the camera was off in the woods. So I then tried to put it back on preset 1 and it was off about 45 degrees from where I had it and where it was before I started the moving.
Is this a Circuit issue or is my Belt just bad and needing replacement? I will admit I had this issue once before and I reboot the camera and the presets came back as being right after a reboot. I have since started doing a Daily Reboot and until today have not had this type of an issue again.
So I am not sure it is a belt issue, Because out of all the presets that don't go to the area that I setup. There are 2 presets that still do go to the area I set them up for?
Out of all the presets only 9 and 10 are where I had them setup. All the others were off by 45 degrees on the Pan the Tilt was still at the right point.
Anyone else have this issue?
I will admit it is an older PTZ the Amcrest Ip2m-850EB.
