Hello Tech Support,
Few months back i bought NV4116E-HS with 8 POE Cameras and 4 Wifi Cameras. General recording works fine but motion detection doesn't work on any of the Camera.
Camera Model:
Four IP2M-852EB Outdoor Cameras - Firmware version: 2.420
Four IP2M-841EB Indoor Cameras - Firmware version: 2.420
Two IP2M-841B Indoor WiFi Cameras - Firmware version: 2.520
Two IPM-HX1B Indoor Wifi Camera - Firmware version: 2.520
Without the motion detection i don't see any meaning to have this system. Please advise how to fix this problem.
Thanks
NV4116E-HS -Motion detection doesn't work
Re: NV4116E-HS -Motion detection doesn't work
NVR version :3.210.AC02.0, Build Date: 2017-06-13
Hello ampatel ,
Please make sure that event is enabled for all channels. The option record channel should be checked as well . This also should be checked for every channel. For eg, for channel 2 only record channel 2 should be selected.
Then under storage > Schedule ensure the schedule for motion recording is enabled. Please give us a call and we hope we can definitely help you with that.
Call Us 1-888-212-7538
