NV4108E and Samsung POE Cameras
I just purchased the nv4108e to replace my dead Samsung sde-4001. I want to use the Samsung cams (sbe1005R) that are already mounted/run throughout the house. Will these work with this NVR? I connected them to back of my 4108E, but no joy. I believe this is because the Samsung dvr itself provided power for each camera since I had a separate power supply labeled camera power. Do I need a POE injector or POE switch. I really like this NVR, and don't want to buy more cameras.
Re: NV4108E and Samsung POE Cameras
Hello 4Chris,
Unfortunately the other brand camera is not compatible with our NVR. So we cannot guarantee that they will work even if you get a POE switch.
Wonderful. Even though the description/notes I read stated that Samsung cameras were supported. I will be returning the NV4108E for refund now.
