NV4108 no sound with 841 cams
tkmbe99
Post by tkmbe99 »
Hello
Read a lot of the issue there is no sound with 841 cameras.
I have 5 841 cameras and the NVR NV4108. I cannot hear sound if I connect remote to nvr and show cams.
Using video output of NVR I don't have sound. Do I have to connect chinch connector a part of the monitor connector?
Directly connecting to cam I hear the sound.
I want to record with sound how can I do that?
And of course coping video I want the sound.
Now I o backup from NVR to usb and there is no sound ....
Any help?
Beat
Melvin
Re: NV4108 no sound with 841 cams
Post by Melvin »
Hello tkmbe99,
How are the cameras connected to the NVR? Are they on wifi or hardwired to the NVR? Under the settings for NVR, go to camera > audio/video and ensure that audio is enabled and it should enable audio for recording.
