No reset switch on motherboard! how do i reset camera
fcat
Post by fcat »
How do i reset my IP4M-1026B to factory settings ? Ive followed the instructions online , removed the IR ring and the plug but my camera has no reset button on the motherboard!
https://ibb.co/CPWs7JF
Thanks
Re: No reset switch on motherboard! how do i reset camera
Little confused. Thought the camera you listed has a little panel that gets removed with a reset switch behind the panel where you would also put in the MSD card...
fcat
Post by fcat »
I guess it has after looking! i just googled reset Amcrest IP4m 1026 camera and it came up with talk of removing the cover etc!
thanks
Maybe need to get some info about the information you were told to take your camera apart so I can pass that onto Amcrest and if there is some bad info about how to get to the Reset Switch by taking apart your camera on Amcrest site they can take care of it so others don't run into the same problem. Wouldn't want someone else to get bad info and maybe risk damaging the camera.
