night vision does not work
ckal9
Post by ckal9 »
I have the night vision option selected as auto (if I recall correctly that's the setting name), but night vision has never worked on my camera (IP2M-841 ProHD 1080P (1920TVL) Wireless WiFi IP Camera).
How can I fix this?
Melvin
Re: night vision does not work
Post by Melvin »
Hi ckal9,
Could you please try to hard reset the camera and check whether that fix the issue?.
amcrest168
Post by amcrest168 »
ckal9 wrote:I have the night vision option selected as auto (if I recall correctly that's the setting name), but night vision has never worked on my camera (IP2M-841 ProHD 1080P (1920TVL) Wireless WiFi IP Camera).
How can I fix this?
i suspect the night vision issue is related to a bad firmware. may i ask what is the firmware version of your ip2m-841? i surmise your ip2m-841 firmware is 2.420.AC00.17.R, Build Date: 2017-03-22.
