need help
Re: need help
What are the Camera/Video settings set to? Are you using Amcrest Cloud?
Re: need help
The settings are the default settings. Not using the cloud just straight from dvr to tv.
Re: need help
Hello S&JGram,
Do you happen to have this issue with all the cameras? Check the connection on the back of the cameras as well as on the back of the DVR. They should fit in properly without any loose contact.
