I've update my IP2M-841B
Code: Select all
from fw 2.520.AC00.18.R. 2017-06-29 to 2.420.AC00.18.R. 2020-03-30
(which figure in page as 3/30/20 and file is Amcrest_IPC-AWXX_Eng_N_AMCREST_V2.420.AC00.18.R.20200330.bin)Code: Select all
from X to 2.620.00AC00.3.R. 2020-03-30 to 2.620.00AC00.3.R. 2020-03-30 (which figure in pas as 3/30/20
and file is Amcrest_IPC-AWXX-V2_Eng_N_AMCREST_V2.620.00AC00.3.R.20200330.bin)Since this upgrade camera has not anymore valid sound recording.
I'm using a NVR NV4116-HS
Code: Select all
with System Version: 3.215.00AC000.0 Build Date 2018-01-05
I see this NVR has FW V4.000.AC000 Build Date 5/21/20Trying to play exported records with vlc or xine tells me undefined audio codec but the old videos are playing sound.
I'm using Codec AAC/16000 so I can show it on linux (because G.711X did never work)
What is the problem?
Do I have to downgrade fw? I like the new version because you can see the live video with firefox and chrome and you don't need the plugin
which is not even anymore available for new windows versions.
Or Is the problem really old fw of NVR?
Can I downgrade without any problems cam fw and NVR fw?
Greetings and thanks
