IP8M Firmware Issue
kgreen29
IP8M Firmware Issue
Post by kgreen29 »
I have a few 8mp vandal resistant poe dome cameras. I recently updated them to the latest available firmware and for some reason the highest fps has dropped from 15 to 14. 14 is the highest it will go. Previous firmware allowed 15 fps. Is this a bug. Its supposed to be 15 fps at 4k.
Update: Appears to be fine when the camera is running standalone. Adding to amcrest nvr of which I have the 16 channel 4k seems to change the fps max down to 14 at 4k. If I factory default it goes back to 15. Readd to nvr it shows 15 initially then next login the max drops down to 14 again. So the bug must be with the nvr firmware.
