IP3M-956 Power Extension Cable
cwalins
Post by cwalins »
Is there a power extension cable for the IP3M-956? If not, then can I get the specs for the connectors used? I tried the 10FTEXTW but the connectors are different.
Melvin
Re: IP3M-956 Power Extension Cable
Post by Melvin »
Hello cwalins,
The size of the connector is 5.5x2.1mm. You could try something like the one in link below.
https://www.amazon.com/Ganewry-Universa ... ower+Cable
