IP2M-858 Max Frame Rate
sperok
Post by sperok »
In the online technical specification .pdf for the IP2M-858W the frame rate for the main stream is listed as 60FPS. Other literature says 30FPS. Does anyone know if this camera (or any other) can actually deliver 1080P at 60FPS with a lens that is at least 50mm (usually a 10x or higher zoom)? The application is for baseball/softball, we want a tight shot of home plate from the center field camera so that we can build our own analytics applications.
jack7
Re: IP2M-858 Max Frame Rate
Post by jack7 »
The max. rate of my IP2M-858 is 30fps. I don't know of any 60fps Amcrest cameras. I have sent you a private message. Log in to this forum and click Private Messages at top right.
