IP2M-853EW H265 Low Latency settings
Nick
Post by Nick »
Hello, I'm trying to tweak an 853E for the lowest latency possible.
I've got it on my bench wired to a router and connected directly to its IP through a web browser. If I ping the camera I'm seeing an average of under 1ms which is to be expected. However, there is much more lag than I was expecting using H265 and a directly hardwired TCP connection.
If I max everything and switch between 1080p and 720 there's no preceivable difference in latency. Even if I choose the lowest quality settings, I dont see a speed increase, just smaller data stream. "Realtime" in the live view screen is also selected.
Is there a faster way to connect to the camera? Can anyone recommend settings for the lowest latency possible?
Appreciate the help.
