Reboot of the Camera? Yes, both streams resume after reboot. (reboot being umplugging/moving/replugging to power)Revo2Maxx wrote: ↑Tue Jan 21, 2025 12:52 pm 1 thing you might not have tried. If not give it a go.. Doing your test with a reboot and see if things remain as it did without the reboot? Normally in the past. Wifi enabled and wired connected could access the device on wifi IP even with out wifi on the router being active because it was connected over wired. It has been a while if wired IP worked on Wifi I don't think it did..
Ok...
I have NOT tried to access the WIFI IP with the WIFI disabled, and ethernet cable on.
That one time, I could access the WIRED IP over a WIFI only connection. Wire unplugged. But I was unable to duplicate it, so I consider it an anomaly at this time. Just thought it was worth sharing.
But yes indeed, both streams are present with a wire connected and WIFI enabled on the camera. EDIT - and default Ethernet card set to Wired on the camera.
