ip cameras
davidekite
ip cameras
Post by davidekite »
ip2m-863ew-ai camera i have 20 amcrest cameras all work away from camera wifi except this one will not
Re: ip cameras
If that is the Camera Model you have that camera isn't a Wifi camera it is POE only.
From what I know the 863, 1063, and 1083 AI cameras all all only POE there was an older 12x version of the PTZ camera that was Wifi can't remember if it was the 853 or 858 but one of them was Wifi..
Very important things to note about this camera, It needs a good Copper cable and a POE switch in the at format aka 802.3at and aka POE+. If the camera comes with a power cord then it can work with the power and any Ethernet cable that is wired straight though will work.
