How to Upgrade IP2M-841B Firmware
I am at a loss and cannot find how to upgrade IP2M-841B firmware. The ArmCrest.com search sucks!
Re: How to Upgrade IP2M-841B Firmware
I suggest you try downloading the user manual PDF, located under the Support drop down. That info and much more are located there. The PDF info probably isn't searchable. (and I'm not being snarky - lots of documentation there)
For the record that's under System - Upgrade.
Thanks for the pointers! I'll take a look. I appreciate your help.
No problem - I've been burned like that doing searches on other websites than here. Good luck flashing.
I saw "System - Upgrade" earlier, but "System" didn't click as "camera firmware". "System" means something completely different to me.DavidN wrote:For the record that's under System - Upgrade.
Hello,
You can manually download the firmware on your PC from the below link.
https://amcrest.com/firmware]
Then from the cam webinterface on PC, go to set up > System > Upgrade. Click on the 'browse' option to next to the 'Select Firmware file' and select the file you have downloaded. Click upgrade and wait for the upgrade status message.
None of the buttons seem to work on the page. I tried in I.E., Chrome and Edge. Any ideas?
Did this ever get resolved? I'm running into the same issue.
Hello Nillies ,
Not sure what exactly is the issue that you are encountering. Could you please give us call so that we can take a look?
https://amcrest.com/contacts
Thank you Melvin. I was not able to upgrade the firmware on the device because the webpage was not working properly. I called support and they used Teamviewer to connect with me and help me through the issue.
Resolution: Do not use the link supplied in Amcrest Survelliance Pro application. Instead just browse to the IP address of your device in Firefox or IE. The setup screen actually works from here and it has automated firmware updates so that you don't have do download and install it manually.
