Fast forward speed 8X?
I have a NV4108E-HS and am shocked that you can only fast forward 8X. Every other DVR i have had could do up to 32X. If i need to watch some footage to find an event that happened in about an hour period, it just takes forever. Is there a fix for this or another program i can use to search quicker?
Re: Fast forward speed 8X?
Amcrest Smart Play plays DAV files and others at 1/64X to 64X. A user guide should be in the Smart Play folder.
