DVR will not full power up
bassinrhino
Post by bassinrhino »
I checked and everything is connected correctly. When I turn on the DVR switch on the back, a red LED lights up inside, and the green and orange lights for the ethernet connection light up. Pushing the power button on the front of the unit does nothing, and the unit is not filly powered up. Also, the fan has not turned on yet, even though I can feel heat being generated inside the unit. And I do not see anything on the monitor. Any ideas? Thanks, Dave
Melvin
Re: DVR will not full power up
Post by Melvin »
Hello bassinrhino ,
Did you connect this to an HD TV with HDMO cable? In this case you might first need to connect using a VGA cable and change the video output to 1080P. Also, if you have it connected to router, you can access the web interface of the DVR from the computer and change this settings. Please contact our technical support if the issue persists.
https://amcrest.com/contacts
