DDNS Settings Keep Resetting After Restart
dcblair
Post by dcblair »
Hi. I have the dvd system showsn here: https://amcrest.com/amcrest-amdv7218-4b ... meras.html.
I find however that whenever I restart the DVR system, the DDNS settings go back to default. I keep having to set it back to what it should be.
How can I fix this?
Melvin
Re: DDNS Settings Keep Resetting After Restart
Post by Melvin »
Hello dcblair,
Which DDNS service are you using?
dcblair
Post by dcblair »
I am using noip.
Melvin
Post by Melvin »
Hello dcblair,
Please try using a different DDNS service like Amcrestddns. In the DDNS list there should be an option for this.
dcblair
Post by dcblair »
Hi. I am still having the problem no matter what I change it to.
Melvin
Post by Melvin »
Hello,
Could you please contact our support team by phone? We may need to do further troubleshooting to figure out the issue.
https://amcrest.com/contacts
luminus777
Post by luminus777 »
sorry to bring up an old thread, but I have the same issue, 4 channel 720p DVR, AMDV7204-2B2D
everything is configured and working fine, but if the system is restarted or there is a blackout...network settings come back with the factory default settings..so I have to reconfigure the static ip and the DDNS settings
seems more like a glitch with the software in the DVR. any ideas?
eeleor
Post by eeleor »
mines doing the same thing. i updated firm ware and its doing the same thing as yours. did you finally get a solution
