Continuous recording on SD card with spotty wifi on ProHD 1080
ataxia
Post by ataxia »
Hello,
I'm looking for a security camera that would continuously record footage (24/7, even without motion) on the SD card. My wifi is unreliable so I cannot depend on it.
Here's the camera:
https://www.amazon.com/Amcrest-1920TVL- ... B0145OQTPG
Edit: There's also that one, but what the difference is between the 2 I have no idea:
https://www.amazon.com/Amcrest-ProHD-Wi ... B01FEEKB7I
The camera seems to be able to record on the SD card continuously. But what about the wifi? Will the recording continue even if my connection drops (although I'm recording exclusively on the SD)?
Thank you for any info you might have.
Best,
Jacques
