Can't get Engenius EDS1130 cameras to work with NV4116E
Hey
Post by Hey »
Any ideas how how to make these these Engenius EDS1130 cameras work with an NV4116E? They don't show up with the device search so I tried adding them manually without success. They work perfectly fine with Blue Iris but when I try to connect them to the NVR I immediately get a login error even though I'm using the correct info. I've tried tweaking everything I can think of but they just won't connect.
Also having issues with some cheap Chinese cameras (IPCC-MPO720E ONVIF). They show up in the device search but only connect for about 5 seconds at a time and then lose the connection for about 10 seconds and just continue dropping in and out.These also work fine with Blue Iris. Tried tweaking various settings to no avail.
Does this system actually work with any IP cameras besides Amcrest IP cameras? Tech support was no help. The guy I spoke with didn't even know that the Switch built into the NVR has to be on a different IP scheme from the router it's connected to which is just frustrating to me once I figured it out. Any help with making third party cameras work would be greatly appreciated. Thanks in advance!
