Cameras will not recognize wifi
raysmithtx
Post by raysmithtx »
3 cameras not working. I deleted all programs and reset all cameras. Tried to update the firmware but the IP Config program will not work. When cameras are connected to the ethernet cable I can see the camera in live view on my iphone. Note I can NEVER see the camera on the Surveillance Pro desktop program though. When disconnected from the ethernet cable the light blinks green ( I don't know if that good or bad) but I cannot get any images on the iphone (I can see a "Network not available") message below where the image should be. I have checked the router IP address and there are other devices on the 2.4ghz network so that is not the problem.
I would appreciate some help on this.
mrcleanstl
Re: Cameras will not recognize wifi
Post by mrcleanstl »
Have you configured the cameras to use WiFi in the NET section of the IP CONFIG program?
mordeo
Post by mordeo »
Make sure you don't have wifi and ethernet enabled on the device at the same time. I've read this causes issues.
