Cameras offline?
reddoor
Cameras offline?
Post by reddoor »
On some of my computers, I can access all cameras on all of my Amcrest devices, however on others, I cannot access any. On the computers in which it doesn't work, Amcrest Pro is saying that all my devices are offline. Any advice?
Re: Cameras offline?
So I am going to guess that your talking about ASP aka Amcrest Servalince Pro..
It all depends on how the cameras are setup within each computer.
Depends on how many computers are currently active and how your cameras are setup for connections
Depends on quality of Network connection between cameras, computer and Switches or routers
also depends on if the cameras are within the same area as the computers connected.
So lets say that you setup your system with IP and then you copied this info onto another computer that is say outside your network maybe within a Subnetwork of your network even if the computer were not setup with the cameras right then there would be connection issues..
Another thing and I am not 100% sure but also could be a Multicast issue depending on how your system is setup..
