Camera Problems in Korea
My camera worked fine in the USA and the setup was flawless. Having many problems in setting it up now that I am in Korea. Could the internet protocol be different? Only can use P2P. Cannot set up wireless or ethernet method.
Re: Camera Problems in Korea
It should be the same. I can only guess the router you or the camera is connecting to somehow blocking it.
IP2M-851E with remote FTP for snapshots.
Hi ems1122,
Most of the amcrest connects to 2.4ghz wifi please make sure you are using supported wifi frequency. If you are facing any trouble configuring from phone try to do it from computer using Amcrest IP config method.
