Hi,
I've got am IPM-721S camera set up to record continuously onto 64GB SD card. Problem I'm having is when it detects movement it seems to stop recording audio for a while. Video carries on recording, just with no audio. Anyone know how to stop this happening? Its very annoying and defeats the object of having the camera set up really...
Cheers,
Gordon
Audio recording issue.
Re: Audio recording issue.
Hello gordyh ,
In the camera set up under Camera > Video > Audio ensure that the encode mode is set to AAC. Also if the camera is on wifi and is affected by low wifi signals, it can cause the issue.
Thank you for advice!Melvin wrote:Hello gordyh ,
Cheers,The mechanicguides.com
