Amcrest 1080P Won't Connect To WiFi, Previously Worked
webmonk
Post by webmonk »
I have been using three cameras for months without issue. A few weeks back I changed the WiFi password and while updating a slew of devices I finally got to the cameras, because I noticed that they were no longer accessible via the surveillance pro software. So, I opened the app on my cell phone, deleted the cameras and started the process of adding them back (this was the only way I could find to update the WiFi password). After I got to the step where I entered the new WiFi password it beeps and shows it is configuring the camera. But it always fails after a minute or so. I have tried it with two of the cameras, multiple times.
Any idea what is going on and how to get these back online again???
t84a
Re: Amcrest 1080P Won't Connect To WiFi, Previously Worked
Post by t84a »
You need to reset the cameras.
Melvin
Post by Melvin »
Hello webmonk ,
It would be better to hard reset the cameras and start over if possible.
webmonk
Post by webmonk »
Thank you t84a and Melvin, a reset is exactly what was needed! :D
