Hello everyone!
My current system is AMDV7208M-8B-B its 8 channels 720p cameras, I'm looking to replace one camera with wider angle . i found that Amcrest IP2M-841 ProHD 1080P (1920TVL) Wireless WiFi IP Camera has about 90 degree viewing angle. Thats about what i need, Will this camera work with my NVR ? Can I set it up so it will record as one of the 8 channels , and not just for a live view.. any help will be appreciated
adding 1080p camera to my 720p nvr. Help Please!!
Re: adding 1080p camera to my 720p nvr. Help Please!!
Hello Rpnim123 ,
Yes you can add two IP cameras to the DVR. Since the DVR is 720P, you can add the 720P indoor camera like the one below which has 85 degree viewing angle.This is indoor camera and is recommended to be used only indoors.
https://amcrest.com/amcrest-720p-wifi-v ... t-387.html
