8 channel 1080 nvr no.audio issue
orangedoors
Post by orangedoors »
Bought this one not long ago. Have 5 ip cameras hooked up to it. All foscam, 2 outdoors with no mic, and 3 indoors with mic... the fi8918w, and the fi8910. I can hear the audio whennusing the tiny cam app on my android, yet unable to hear any audio while wwtching the recorded material on the nvr.
As read here, i am trying to setup the audio at the system--》 audio/video encoding, yet receiving always a msg that search, or change if settings is impossible. Is it a bug. Or is it security privileges issue.?
Thank you
Melvin
Re: 8 channel 1080 nvr no.audio issue
Post by Melvin »
Hello orangedoors,
Foscam and other brand cameras only have very limited compatibility with Amcrest NVR's. So you might not be able to change settings or use features like audio recording with it.
orangedoors
Really. That is a shame.:-(. I.made.comprehensive reaearch beforw buying this nvr, as it appeared the most comparible to work with the foscam cameras. Very dissapointing.
