2 way communication not working after NVR introduction
Adelzee
Post by Adelzee »
Hello,
I have at home 5 1080pro wireless cameras.
Everything was working fine, all features OK.
Then i have decided to purchase an 8 channel NVR for better recording.
I didnt change any settings, still connected on the same wifi.
All works fine on the NVR but 2 way communication has stopped.
Everytime i try to use the 'mic' feature on my apple phone, no sound come out of the cameras.
This feature was working when no NVR was present.
This is a very important feature to monitor my kids.
Thx!
Melvin
Re: 2 way communication not working after NVR introduction
Post by Melvin »
Hello Adelzee ,
The MIC feature does not work when the cameras are added to NVR. If the cameras are connected to the router wireless, you can add the cameras individually on the app and that will give you the MIC option while its still added and recording on the NVR.
