My 10808 s-3 continually reverts back to two hours ahead after I sync it with my pc
I have called tech support twice , reset to default time setting, saved it, then sync with pc, saved that as well. Time stamp changes to correct time for an hour or so then automatically changes to two hours ahead. The second tech downloaded latest firmware for me through auto view, that too only worked for about an hour.
How about someone from Amcrest give me the right answer. It appears to be a chronic problem with many machines.
10808 s-3 time stamp problem
Re: 10808 s-3 time stamp problem
I have 3 DVR system AMDV10808-S3 and I am facing the exact same issue.
