Hi folks.
According to the Amcrest NVR Quick Start Guide v4.04 (Rev. May 18, 2016) page 4, it says in the Figure 1 table to "Press and hold the Power button for 3 seconds to boot up or shut down the NVR".
I tried the 3 and even a 10-second hold down and it still won't shut down. Is the power button on the recorder (NV1104E) defective?
Please help.
Help! NV1104E power button defective??
Mark_Aardvark
Re: Help! NV1104E power button defective??
I also found that the power button does nothing.
Cutting power by removing the plug does not appear to have negative consequences thus far.
FinickyBob
The power button, sadly, is only one-way -- just to turn on the unit -- after that it does nothing. I'm thinking of ditching this and getting a Dahua NVR. At least, it's more solid and robust than this buggy one.
