Using Android 14
Using Android 14
So just wondering if there is anyone with issues related to using Android 14 yet? I was set to install on the 22nd however I elected to install it early and so far things seems to be working alright with AVP on 14. I will admit that if I close the app and bring it back up very shortly after (Less then 3 or 4 minutes) that I have to refresh my cameras to get them to start up again. Where before the update I didn't have to do that? It might not be related to the update. Only issue that I seem to be having right now. However I just checked the app again and it has been over 30 min since I last looked at it and the camera feeds loaded as it normally would. So maybe the app time out is to long after being closed out? I mean it isn't like I closed it really just set it to the background really.
mcdye
Re: Using Android 14
Post by mcdye »
Samsung/14/AVP 4.2
I am not experiencing that. I close the app, wait a minute, go back and loads as expected.
Thanks for the Reply. Yeah only have had that issue a couples on the 8th. I normally don't reopen right away so if it is just my phone and not software related I wouldn't really know. I tried a couple of times today and didn't have the same issue. Only did it to test out. Worked fine. Maybe it was only a Fluke. Wasn't anything that I had to deal with before and only thing different was I updated to 14 and thought maybe it could be related.
