iPad not using full screen for Amcrest View Pro
geronimo
Post by geronimo »
I was using a Samsung Tab 7" as a monitor for my cameras. I bought an iPad Air 9.7" so that the view would be larger. However, View Pro does not use the full screen on the iPad and I ended up with about the same size video. Is this normal? Does the iPad not have a way of viewing this app with the full screen?
Thanks.
jack7
Re: iPad not using full screen for Amcrest View Pro
Post by jack7 »
It's old, but try "Amcrest View Pro for IPad" in app store. It  should provide a bigger image.
geronimo
Post by geronimo »
jack7 wrote: ↑Wed Sep 07, 2022 4:48 pm It's old, but try "Amcrest View Pro for IPad" in app store. It  should provide a bigger image.
Outstanding! That did the trick.
As you may have guessed, I just transferred everything over from my iPhone which did not include an app specific to iPad.
Thanks much for your help.
