Does Amcrest View Pro Encrypt Login Info?
EddieColeslawski
Post by EddieColeslawski »
As the title says. I am paranoid about logging into my system from outside of my internal network.
Re: Does Amcrest View Pro Encrypt Login Info?
Using P2P your Password is your SN isn't
EddieColeslawski
Thanks- what about with IP/DDNS login?
jack7
Post by jack7 »
EddieColeslawski wrote: ↑Tue Sep 22, 2020 9:14 pm As the title says. I am paranoid about logging into my system from outside of my internal network.
Suggestion:
Use VPN for a fully secured connection.
https://ipcamtalk.com/wiki/how-to-secur ... et-hacked/
EddieColeslawski
Thanks Jack! I do port forward to my cameras as a matter of necessity, but I use strong passwords on them. Now I’m more nervous...
