Just installed the firmware update for my camera....loaded latest IOS amcrest view pro to my IPAD....tried to sign on to the camera to set up wireless using this app. I entered name: elected to keep admin/admin but NEXT doesn't work...I then tried to change userid/pw and NEXT still doesn't work. Application does not work!!! BTW...it doesn't matter if you scan the serial or enter it manually...you can't get past the name/pw/confirm pw screen on an IPAD.
I finally used Amcrest View Pro Lite and that worked.
Terrible software....
can't add camera - Amcrest View Pro IOS - firmware update
James.S
Re: can't add camera - Amcrest View Pro IOS - firmware update
Please reach out to us via email as we would like to work with you directly to resolve the issues your running into.
email (support@amcrest.com)
