I am awaiting the NVR's arrival. Its out for delivery.Revo2Maxx wrote: ↑Tue Jan 21, 2025 12:32 pm The setup of the NVR will be fast and easy for any Amcrest or Dahua Cameras. Other devices can't say the same. But most cameras I have tried work with my NVRs from Amcrest. Now if your POE doorbell offers ONVIF then it should be fine on your Amcrest NVR and yes using the P2P to access the NVR will let you view your other brand cameras over the Amcrest NVR/Amcrest App.. Having total control and or access to Ai that might have on the doorbell wouldn't work unless it was Amcrest and or Dahua related.. The A2 is a Semi Ai NVR and will work with Amcrest/Dahua Ai cameras.
There is some AI on the doorbell cam, but even if not accessible via NVR I may be able to set it up either using its app(s) (App Guarding Vision or Hik Connect) or via its connection to BI. Even if not, it will fulfill all our needs.
THANK YOU!!!!!
