Amcrest View Pro 2 for Android?
Frizzo
Post by Frizzo »
Where can I download Amcrest View Pro 2 for Android? I see it's available for iOS in Canada.
longedge
Re: Amcrest View Pro 2 for Android?
Post by longedge »
Welcome to the forum.
Does this link work for you? - https://play.google.com/store/apps/deta ... estViewPro
I don't have any Android devices so can't be sure, but the page states the last update was on 1st August 2023 but it's not clear, to me at least, whether that was just to the information on the page or to the app.
My AMCREST Cameras:-
Frizzo
Post by Frizzo »
That link works but there is a v2 available. But not available for me.
https://play.google.com/store/apps/deta ... d.AMCREST2
longedge
Post by longedge »
I have to admit that I wasn't even aware that there's a V2. I downloaded it on my iPhone via the app store and have it set up and working (although that's no help to you). If there are no other replies from users on the Forum then I'd suggest getting in touch with Amcrest as per the support pages - https://amcrest.com/contact/
Sorry that I can't help further.
Pogo
Post by Pogo »
The Play Store says it's compatible with my Android LG but I'm reluctant to install it since the existing version works great for me as is.
longedge
Post by longedge »
Pogo wrote: ↑Fri Sep 15, 2023 4:17 pmThe Play Store says it's compatible with my Android LG but I'm reluctant to install it since the existing version works great for me as is.
I've deleted it again. Not saying that V2 was definitely responsible but I think it was. One of my cameras suddenly decided that it was on a different network segment and I've spent the better part of yesterday evening and this morning doing endless factory resets and reboots and finally got things back to normal after about 10 hours turning the air blue around me, I wish I'd got more patience :P
Frizzo
Post by Frizzo »
I have a Pixel 6 and it says its not compatible, like WTH.
Frizzo
Post by Frizzo »
How can I get the apk? Can someone from Amcrest provide this?
Frizzo
Post by Frizzo »
Anyone?
Frizzo
Post by Frizzo »
Was able to get it. Had to create a USA gmail account, then use a VPN to show that I'm from the USA.
