ASP and PC-NVR
blastradius
Re: ASP and PC-NVR
The webui works fine for each camera but i want a centralized software to handle recordings. I would really like to figure out why the NVR keeps stopping, when it works well It seems like it would be just fine but for somereason the PC-NVR has issues. Am I the only one reporting these issues?
Re: ASP and PC-NVR
I guess there needs to be some info about what and how!?
So I have PC-NVR setup to Record some of my Random cameras and I don't have it setup for anything outside of Motion and IVS because I am limiting the HDD space for ASP and PC-NVR..
So my ASP crashed last night and I said to heck with bring it back up. So I just did now and PC-NVR has been working just fine in the background as it is expected to.
So then I have to ask. Do you have your PC-NVR setup to Auto Run?
Did you setup your Pc-NVR to Record your cameras?
Are you trying to playback Footage from PC-NVR or from the Cameras?
Are you using AI or Motion for triggers?
So I have mine setup to work with 2 4mp cameras. one in AI mode and one in Motion Event mode. Both have Recorded events today as expected even after ASP closed yesterday. I do keep my computer online 24/7
